Design of Experiments Guide > Compare Designs > Compare Designs Window: Specify Model and Alias Terms
Publication date: 07/30/2020
The Compare Designs window consists of two sets of outlines:
Specify which effects are in the model and which effects are potentially active using the Factors, Model, and Alias Terms outlines.
Compare the designs using the diagnostics in the Design Evaluation outlines. Changes that you make in the Model and Alias Terms outlines are updated in the Design Evaluation report.
The Compare Designs report uses the column names from the reference design.
This section describes the Reference Design, Factors, Model, and Alias Terms outlines. See Compare Designs Window: Design Evaluation for a description of the Design Evaluation outlines.
