Publication date: 07/30/2020
Competing Cause Report
Tip: If you find that the report window is too long, select Tabbed Report from the Competing Cause red triangle menu.
The Competing Cause report appears if you have assigned a Failure Cause column in the launch window. Use this report to analyze the competing causes to determine which causes are influential. For an example of this report, see Omit Competing Causes. For technical details, see Competing Cause Details.
The Competing Cause report contains the following content and options:
Cause Combination
Competing Cause: Statistics
Individual Causes
Competing Cause Report Options
