Publication date: 07/30/2020
Configure Components
1. In the Configuration panel, enter the Configuration settings for the components. See Configuration Settings.
Table 11.1 Configuration Settings
Component
Settings
Power Supply
Distribution—Exponential
Theta—1
CPU
Theta—1
Peripherals
Distribution—Weibull
Alpha—1
Beta—2
N—3
Hard Drives
Alpha—2
Beta—1
K—1
N—4
Join
Minimum available—1
Input Devices
Distribution—Fréchet
Location—0
Scale—1
N—2
Monitor
Theta—1
The Reliability Block Diagram is complete (Figure 11.11).
2. Select Run.
The system’s reliability information is updated. This is reflected in the Distribution plot in the Profiler pane.
3. To save the Reliability Block Diagram as a JMP Scripting Language (JSL) file, select File > Save and name it exampleRBDcomplete.jsl.
Figure 11.11 Example Reliability Block Diagram
