Using JMP > Save and Share Data > Create a Journal > Control the Display of Outline Levels
Publication date: 07/30/2020
You can instantly control which outline levels are displayed (for example, closing all sublevels below the selected level). Click the red triangle for that level, select OutlineBox, and then select one of the Open or Close commands. For more information about the Open and Close commands, see Access Report Display Options in the JMP Reports section.
Tip: On Windows, show the OutlineBox options by holding down the Alt key and right-clicking the outline level’s gray disclosure icon.
