Design of Experiments Guide > Covering Arrays > Covering Array Window
Publication date: 07/30/2020
The covering array window updates as you work through the design steps. For more information about the general flow of DOE windows, see The DOE Workflow: Describe, Specify, Design. The outlines, separated by buttons that update the outlines, follow the flow in Figure 20.17.
Figure 20.17 Covering Array Flow
