Design of Experiments Guide > Definitive Screening Designs > Definitive Screening Design Window
Publication date: 07/30/2020
The definitive screening design window updates as you work through the design steps. See The DOE Workflow: Describe, Specify, Design in the Starting Out with DOE section. The outlines, separated by buttons that update the outlines, follow the flow in Figure 7.16.
Figure 7.16 Definitive Screening Design Flow
