Publication date: 07/30/2020
Event Settings
Select an event in the System Diagram to see its settings in the Configuration panel. You can change the Event Name setting to distinguish the event from others. Only the Scheduled and Inservice events have additional settings, which are listed here:
Scheduled
Scheduled events have the following options:
Recurring Interval
Specifies the length of the time interval between event occurrences.
Max Occurrences
Specifies the maximum number of times this event can occur.
Inservice
Inservice events have the following options:
Inservice
Specifies the interval of component run time to wait before this event occurs.
Note: Component run time accumulates only when the system is in the On state and the component is functional.
Max Occurrences
