To view settings for the components in a selected design or subsystem, do the following:
• To view the Configuration settings for a block shape, select the block shape in the System Diagram.
• To view Configuration settings for more than one block shape, select multiple block shapes using the Arrow tool, press Control, and click multiple block shapes.
Each block shape randomly fails according to its specified failure distribution. In addition, you specify a time unit for the distribution. The block shape’s time unit can be different from the time unit option that you specify in the simulation settings. The Turn On Count option is based on the number of times the individual block shape has been set to the On state.
The available failure distributions are listed in Table 12.2.
Property Type | Required Inputs |
Exponential | Theta |
Weibull | Alpha, Beta |
Lognormal | location, scale |
Loglogistic | location, scale |
Fréchet | location, scale |
GenGamma | mu, sigma, lambda |
DS Weibull | Alpha, Beta, Defective Probability |
DS Lognormal | location, scale, Defective Probability |
DS Loglogistic | location, scale, Defective Probability |
DS Fréchet | location, scale, Defective Probability |
Nonparametric | data or data file |
Estimated | estimated distribution, data or data file |
To see the formulas and parameterization for these failure distributions, see Distributions in the Life Distribution section.
