Use Graph Builder to explore multidimensional relationships easily and flexibility. You can quickly create and modify plots using Graph Builder’s interactive interface. Select the variables that you want to graph and drag and drop them into zones.
Use Graph Builder to do the following:
• Graph data in a multitude of ways, including line charts, bar charts, histograms, maps, contour plots, and many more.
• Experiment by changing the graph type with the click of a button.
• Compare groups with overlays or trellis layouts.
• Examine and illustrate relationships between several variables of different modeling types.
• Use color to highlight aspects of your data.
This chapter shows you how to use Graph Builder to work with plots. For detailed examples using Graph Builder, see Graph Builder Examples .
Figure 3.1 Example Using Graph Builder
