Essential Graphing > Graph Builder > Right-Click Menus > Options for the Dividing Line between Multiple Graphs
Publication date: 07/30/2020
This menu appears only if you have two or more graphs in the graph area. Right-click the line that separates graphs. Options appear that change the formatting of the line, such as color, transparency, spacing, and borders.
Tip: If the line between the graphs is too thin, you can resize it. Click the Graph Builder red triangle, select Graph Spacing, and enter a larger value.
