Using JMP > Import Your Data > Import XML and JSON Files > Import XML Files Directly
Publication date: 07/30/2020
JMP can detect the structure of an XML or JSON file and import it directly into a data table. If you don’t want to see a preview of the data in the XML Import Wizard, use this method.
1. On Windows:
Select File > Open.
Set the file type to Data Files.
Select the file.
Next to Open as, select Data (Best Guess).
2. On Mac:
Select File > Open and select the file.
Click Options on the lower left corner of the window.
Select Data (Best Guess).
3. Click Open.
The file opens as a data table.
If you are not satisfied with the results, consider using the XML Import Wizard to customize the import. See Import XML Files Directly.
