Multivariate Methods > K Means Cluster > Iterative Clustering Report
Publication date: 07/30/2020
When you click OK in the launch window, the Iterative Clustering report window appears, showing a Control Panel for fitting models. See Iterative Clustering Control Panel. As you fit models, additional reports are added to the window. See K Means Report.
Iterative Clustering Options
See Local Data Filter, Redo Menus, and Save Script Menus in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
