Publication date: 07/30/2020
K Means Report
Each K Means report gives the following summary statistics for each cluster:
The Cluster Summary report gives the number of clusters and the observations in each cluster, as well as the number of iterations required.
The Cluster Means report gives means for the observations in each cluster for each variable.
The Cluster Standard Deviations report gives standard deviations for the observations in each cluster for each variable.
