Basic Analysis > Introduction to Fit Y by X > Launch the Fit Y by X Platform > Launch Specific Analyses from the JMP Starter Window
Publication date: 07/30/2020
From the JMP Starter window, you can launch a specific analysis (Bivariate, Oneway, Logistic, or Contingency). If you select this option, specify the correct modeling types (Y and X variables) for the analysis (Table 4.1).
To launch a specific analysis from the JMP Starter Window, click the Basic category, and select a specific analysis.
Most of the platform launch options are the same. However, the naming for some of the Y and X platform buttons is customized for the specific analysis that you are performing.
Table 4.1 Platforms and Buttons
Platform or Analysis
Y Button
X Button
Fit Y by X
Y, Response
X, Factor
Bivariate
Y, Response
X, Regressor
Oneway
Y, Response
X, Grouping
Logistic
Y, Categorical Response
X, Continuous Regressor
Contingency
Y, Response Category
X, Grouping Category
