Design of Experiments Guide > Nonlinear Designs > Nonlinear Design Window
Publication date: 07/30/2020
The Nonlinear Design window updates as you work through the design steps. The outlines, separated by buttons that update the outlines, follow the flow in Figure 23.16.
Figure 23.16 Nonlinear Design Flow
The initial design window shows the Factors, Parameters, and Design Generation outlines.
Figure 23.17 Initial Design Window
