Basic Analysis > Distributions > Options for Categorical Variables
Publication date: 07/30/2020
The red triangle menus next to each variable in the report window contain additional options that apply to the variable. This section describes the options that are available for categorical (nominal or ordinal) variables.
Display Options
See Display Options for Categorical Variables.
Histogram Options
See Histogram Options for Categorical Variables.
Mosaic Plot
Displays a mosaic bar chart for each nominal or ordinal response variable. A mosaic plot is a stacked bar chart where each segment is proportional to its group’s frequency count.
Order By
Reorders the histogram, mosaic plot, and Frequencies report in ascending or descending order, by count. To save the new order as a column property, use the Save > Value Ordering option.
Test Probabilities
Displays a report that tests hypothesized probabilities. See Examples of the Test Probabilities Option.
Confidence Interval
This menu contains confidence levels. Select a value that is listed, or select Other to enter your own. JMP computes score confidence intervals.
Save
See Save Options for Categorical Variables.
Remove
Permanently removes the variable and all its reports from the Distribution report.
