Basic Analysis > Distributions
Publication date: 07/30/2020
Distributions
Using the Distribution Platform
The Distribution platform illustrates the distribution of a single variable using histograms, additional graphs, and reports. The word univariate simply means involving one variable instead of two (bivariate) or many (multivariate). However, you can examine the distribution of several individual variables within a report. The report content for each variable changes depending on whether the variable is categorical (nominal or ordinal) or continuous.
Once you know how your data are distributed, you can plan the appropriate type of analysis going forward.
The Distribution report window is interactive. Clicking on a histogram bar highlights the corresponding data in any other histograms and in the data table.
Figure 3.1 Example of the Distribution Platform
Contents
Overview of the Distribution Platform
Categorical Variables
Continuous Variables
Launch the Distribution Platform
The Distribution Report
Histograms
The Frequencies Report
The Quantiles Report
The Summary Statistics Report
Distribution Platform Options
Options for Categorical Variables
Display Options for Categorical Variables
Histogram Options for Categorical Variables
Save Options for Categorical Variables
Options for Continuous Variables
Display Options for Continuous Variables
Histogram Options for Continuous Variables
Normal Quantile Plot
Outlier Box Plot
Quantile Box Plot
Stem and Leaf
CDF Plot
Test Mean
Test Std Dev
Test Equivalence
Confidence Intervals
Prediction Intervals
Tolerance Intervals
Process Capability
Fit Distributions
Save Options for Continuous Variables
Additional Examples of the Distribution Platform
Example of Selecting Data in Multiple Histograms
Example Using a By Variable
Examples of the Test Probabilities Option
Example of Prediction Intervals
Example of Tolerance Intervals
Example of Process Capability
Statistical Details for the Distribution Platform
Standard Error Bars
Quantiles
Summary Statistics
Wilcoxon Signed Rank Test
Standard Deviation Test
Normal Quantiles
Saving Standardized Data
Tolerance Intervals
Continuous Fit Distributions
Discrete Fit Distributions
Details for the Legacy Distribution Fitters
Fit Distributions Options (Legacy)
Statistical Details for Continuous Fit Distributions (Legacy)
Statistical Details for Discrete Fit Distributions (Legacy)
Statistical Details for Fitted Quantiles (Legacy)
Statistical Details for Fit Distribution Options (Legacy)
