Predictive and Specialized Modeling > Statistical Details > Platforms That Support Validation
Publication date: 07/30/2020
This appendix lists the types of cross validation available in each platform. The types of cross validation are defined as follows:
Use Excluded Rows as Validation Holdback
Uses the excluded rows in the data table as a validation holdback set.
Note: For platforms that support using excluded rows as a validation holdback set, the excluded rows are used only when there is no validation column or validation proportion specified in the launch window.
Random Validation Holdback
Randomly divides the original data into the training and validation sets. A test set can also be included. You can specify the proportions of the original data to use in each set.
K-Fold Cross-Validation
Divides the original data into K subsets. In turn, each of the K sets is used to validate the model fit on the rest of the data, fitting a total of K models. The model giving the best validation statistic is chosen as the final model.
Note: For some platforms, specify in model control launch. For others in launch. For still others, through validation column
Validation Role Column
Uses the column’s values to divide the data into parts. The column is assigned using the Validation role on the platform’s launch window.
Note: Different platforms treat a column with more than 3 levels differently. See notes in the following table.
Platform
Fit Model > Fit Least Squares
No
No
No
Yes (for model evaluation only)1
Fit Model > Forward Stepwise Regression
No
No
Yes (for continuous response models only)
Yes
Fit Model > Logistic Regression
No
No
No
Yes (for model evaluation only)a
Fit Model > Generalized Regression
No
Yes
Yes
Yes
Fit Model > Partial Least Squares
No
Yes
Yes
Yes
Partition
Yes
Yes
Yes
Yes2
Bootstrap Forest
Yes
Yes
No
Yesb
Boosted Tree
Yes
Yes
No
Yesb
K Nearest Neighbors
Yes
Yes
No
Yesb
Naive Bayes
Yes
Yes
No
Yesb
Neural
Yes
Yes
Yes (through model launch or validation column with more than 3 levels)
Yes
K Nearest Neighbors
Yes
Yes
No
Yesb
Naive Bayes
Yes
Yes
No
Yesb
Support Vector Machines
No
Yes
Yes (through model launch)
Yes
Functional Data Explorer
No
No
No
Yes (must be structured as a “Grouped Random” validation column)3
Discriminant
Optional
No
No
Yesb
No
Yes
Yes
Uplift
No
Yes
No
Yesb
1 If there are more than three levels, the validation column is ignored.
2 If there are more than three levels, the platform uses only rows with the three smallest values.
3 If there are more than two levels, the smallest value defines the training set and all other values define the validation set.
