Using JMP > Save and Share Data > Print Reports
Publication date: 07/30/2020
Print Reports
To print the report in the active window, select File > Print. This command displays the standard window for printing. The appearance of the window depends on your operating system and printer driver.
To insert a page break for printing purposes, follow these steps:
1. Right-click the disclosure icon in the report window.
2. Select Edit > Page Break.
