Using JMP > Save and Share Data > Create a Project > Projects Compatibility
Publication date: 07/30/2020
When you open a project created in JMP 13 or earlier, the project is renamed with the _Original suffix. JMP imports the project and creates a log that explains which items could not be imported. For example, URLs, database queries, and SAS stored processes cannot be imported.
JMP 15 projects cannot be opened in JMP 13 or earlier versions of JMP.
