Publication date: 07/30/2020
Reference Design
The name of the window for the reference design appears in the outline title. The Matching Specification outline lists the specifications that you entered in the launch window.
Factors
Use the Factors outline to add effects to the Model and Alias Terms lists.
The Factors outline lists the factors, using the column names from the reference design, and coded values. Because they are not factors, whole plot and subplot columns do not appear in the Factors outline. However, they are required for the analysis.
