Design of Experiments Guide > Response Surface Designs > Response Surface Design Window
Publication date: 07/30/2020
The Response Surface Design window walks you through the steps to construct a design for modeling a quadratic surface. You can select a central composite design, a Box-Behnken design, or a blocked version of one of these design types. If you select a central composite design, you can adjust the axial points.
The Response Surface Design window updates as you work through the design steps. The outlines, separated by buttons that update the outlines, follow the flow in Figure 11.12.
Figure 11.12 Response Surface Design Flow
