Using JMP > Save and Share Data > Create a Journal > Save the Journal in Another Format
Publication date: 07/30/2020
You can save a journal in another format (such as HTML or PDF). When you save the journal as HTML, buttons and links are active when the file is viewed in a web browser.
Note: The header and footer defined in your printer setup appears in the PDF file. However, you can set the left, center, and right header and footer in a JSL script. Search for the Set Print Footers message in the JMP Scripting Index. (Select Help > Scripting Index in JMP.)
Windows
1. Select File > Export.
2. Select the format. See Save and Share Reports.
3. Click Next.
4. Name and save the file.
macOS
3. Click Next.
4. Name and export the file.
