Using JMP > Save and Share Data > Save Your Analysis as a Script
Publication date: 07/30/2020
After completing an analysis and receiving a report, you might want to save the process that you used to arrive at the report as a JSL script. You can save the script inside the data table, inside the report, or in a separate script window. To do this, click the red triangle in the report title and select the Save Script option that you prefer. See Save Script Menus.
Non-English versions of JMP can save scripts in either English or your local language. See General in the JMP Preferences section.
