This section describes Goodness of Fit tests for fitting distributions and statistical details for specification limits pertaining to fitted distributions.
Note: Some features of distribution fitting have been updated in JMP 15. This section contains details of the older features from previous JMP releases that have been retained for compatibility purposes. These features are available by selecting Continuous Fitters > Enable Legacy Fitters in the red triangle menu for a variable.
Distribution |
Parameters |
Goodness of Fit Test |
Normal1 |
μ and σ are unknown |
Shapiro-Wilk (for n ≤ 2000) Kolmogorov-Smirnov-Lillefors (for n > 2000) |
μ and σ are both known |
Kolmogorov-Smirnov-Lillefors |
either μ or σ is known |
(none) |
LogNormal |
μ and σ are known or unknown |
Kolmogorov's D |
Weibull |
α and β known or unknown |
Cramér-von Mises W2 |
Weibull with threshold |
α, β and θ known or unknown |
Extreme Value |
Exponential |
σ is known or unknown |
Kolmogorov's D |
Gamma |
α and σ are known |
either α or σ is unknown |
(none) |
Beta |
α and β are known |
Kolmogorov's D |
either α or β is unknown |
(none) |
Binomial |
ρ is known or unknown and n is known |
Kolmogorov's D (for n ≤ 30) Pearson χ2 (for n > 30) |
Beta Binomial |
ρ and δ known or unknown |
Poisson |
λ known or unknown |
Gamma Poisson |
λ or σ known or unknown |
1 For the three Johnson distributions and the Glog distribution, the data are transformed to Normal, then the appropriate test of normality is performed.
Type a K value and select one-sided or two-sided for your process capability analysis. Tail probabilities corresponding to K standard deviations are computed from the Normal distribution. The probabilities are converted to quantiles for the specific distribution that you have fitted. The resulting quantiles are used for specification limits in the process capability analysis. This option is similar to the Quantiles option, but you provide K instead of probabilities. K corresponds to the number of standard deviations that the specification limits are away from the mean.
For example, for a Normal distribution, where K = 3, the 3 standard deviations below and above the mean correspond to the 0.00135th quantile and 0.99865th quantile, respectively. The lower specification limit is set at the 0.00135th quantile, and the upper specification limit is set at the 0.99865th quantile of the fitted distribution. A process capability analysis is returned based on those specification limits.
