Predictive and Specialized Modeling > Support Vector Machines > Support Vector Machines Platform Options
Publication date: 07/30/2020
See Redo Menus and Save Script Menus in Using JMP for more information about the following options:
Redo
Save Script
Save By-Group Script
Support Vector Machine Model Report Options
Each Support Vector Machine Model report contains the following options:
Response Profile Plot
Shows or hides the Response Profile Plot.
Support Vector Coefficients
Shows or hides the table of support vector coefficients. Select rows in the table to highlight the support vectors in the original data table and the Response Profile Plot.
Confusion Matrix
Shows or hides the confusion matrix. See Confusion Matrix.
ROC Curve
Shows or hides the ROC Curve. If you use validation, ROC Curves for the validation and, if specified, test sets appear in addition to the curve for the training set. For more information, see ROC Curve in the Partition Models section.
Lift Curve
Shows or hides the Lift Curve. If you use validation, Lift Curves for the validation and, if specified, test sets appear in addition to the curve for the training set. For more information, see Lift Curve in the Partition Models section.
Profiler
Shows or hides the Prediction Profiler. Each response level is represented by a separate row in the Prediction Profiler. For more information about the options in the red triangle menu, see Prediction Profiler Options in Profilers.
Contour Profiler
(Available only when the model contains more than one continuous factor.) Shows or hides the Contour Profiler. For more information about the options in the red triangle menu, see Contour Profiler Platform Options in Profilers.
Surface Profiler
(Available only when the model contains at least one continuous factor.) Shows or hides a surface profiler. For more information about the options in the red triangle menu, see Surface Plot Platform Options in Profilers.
Save Predicteds
Saves the predicted classifications to the data table in a column called Predicted <Y, Response>.
Save Prediction Formula
Saves the prediction formulas to the data table. If the response is binary, a single prediction formula column is added to the data table. If the response has more than two levels, a prediction formula column is added to the data table for each pairwise model, in addition to a formula column for the final prediction.
Publish Prediction Formula
Creates probability formulas and saves them as formula column scripts in the Formula Depot platform. If a Formula Depot report is not open, this option opens the Formula Depot window. See Formula Depot.
Save Probabilities
Saves the probability of each response level as a separate column in the data table, as well as a column called Most Likely <Y, Response>.
Save Validation
(Available only when the Holdback or KFold validation methods are used.) Creates a new column in the data table that identifies which rows were used in the training and validation sets.
Remove Fit
Removes the entire model report.
