Predictive and Specialized Modeling > Support Vector Machines
Publication date: 07/30/2020
Predict Response Categories Using Support Vectors
The Support Vector Machines platform is available only in JMP Pro.
In JMP Pro, the Support Vector Machines (SVM) platform provides a machine learning tool for binary and multi-class classification problems. The SVM algorithm is a supervised learning algorithm that uses the training data to build a model to classify new data.
You can visualize the model classification in the Response Profile Plot. The SVM platform provides misclassification rates, confusion matrices, and ROC and Lift curves to help you determine how well your model fits the data.
Figure 9.1 Response Profile PlotĀ
Contents
Overview of Support Vector Machines
Example of Support Vector Machines
Launch the Support Vector Machines Platform
The Support Vector Machines Launch Window
Model Launch Control Panel
The Support Vector Machine Report
Model Comparison Report
Support Vector Machine Model Report
Support Vector Machines Platform Options
Support Vector Machine Model Report Options
