To compute F-values and degrees of freedom, let p be the rank of . Let q be the rank of , where the L matrix identifies elements of associated with the effect being tested. Let v be the error degrees of freedom and s be the minimum of p and q. Also let and .
Table 5.3, gives the computation of each approximate F from the corresponding test statistic.
Test | Approximate F | Numerator DF
| Denominator DF
Wilks’ Lambda | |||
Pillai’s Trace | |||
Hotelling-Lawley Trace | |||
Roy’s Max Root |
