The following messages for a Fit Life by X object are available only in JSL:
fit_life_object << Set Scriptables( ... );
/* set scriptable options within the profilers in different sections
of the output */
fit_life_object << Get Results
/* return the estimates, standard errors, covariance matrix,
and convergence results for each distribution fit */
