Scripting Guide > Scripting Platforms
Publication date: 04/28/2021
Scripting Platforms
Create, Repeat, and Modify Analyses
If you run the same analysis frequently, you can script it to automate the process. Anyone can then run the script, ensuring the same results every time. To get started, perform your analysis interactively as you normally would with JMP, and then save a script that re-creates that analysis. You can modify the script to further customize it.
Figure 10.1 Typical Workflow for Scripting Platforms
This chapter is about scripting platforms, not reports. Platform object references and report object references receive different types of JSL messages. Platforms can run tests, draw plots, and so on. Reports can copy pictures, select display boxes, or close outline nodes. To learn about scripting reports, see the section Navigate JMP Reports in the Display Trees section.
Tip: For additional scripting help, see the JMP Scripting Index (Help > Scripting Index) and the JSL Syntax Reference.
Contents
Example of Scripting a Platform
Send Messages to a Platform
Conventions for Messages and Arguments
Send Multiple Messages
Find Messages for Objects
Interpret the Show Properties List
Send Messages to an Object
Specify Which Columns to Analyze
Create Column References
Specify Multiple Column Names at Once
Enable Users to Specify Columns
Specify a By Variable
Filter by Value using a Where Statement
Enable User Input
Execute Embedded Red Triangle Options
Make Platforms Invisible
Specify Report Titles
Common Messages for Platform Windows
Scripting Considerations by Platform
Categorical
Control Charts
Distribution
DOE
Fit Model
Formula Depot
Graph Builder
Neural and Neural Net
Partial Least Squares and PLS
Process Capability
Scatterplot 3D
Text Explorer
Explore Outliers
Scripting-Only Messages and Arguments by Platform
Bivariate
Choice
Clustering
Control Chart
Control Chart Builder
Cumulative Damage
Custom Profiler
Distribution
Fit Life by X
Fit Model
Fit Parametric Survival
K Nearest Neighbors
Latent Class Analysis
Life Distribution
Multivariate
Naive Bayes
Neural
Pareto Plot
Partition
Surface Plot
Text Explorer
Time Series
