The Prediction Profiler can be accessed in the following ways:
• The Prediction Profiler can be accessed directly from the Graph menu. When you access the Prediction Profiler in this way, the Prediction Profiler launch window appears. See Profiler Launch Windows in the Introduction to Profilers section.
• The Prediction Profiler can be accessed as a red triangle menu option in many modeling platforms. See Where to Find JMP Profilers in the Introduction to Profilers section for more information about the availability of the Prediction Profiler in different platforms.
• The Prediction Profiler can be accessed from the Model Comparisons platform. Select Profiler from the Model Comparisons red triangle menu.
• The Prediction Profiler can be accessed from the Formula Depot platform. Select Profiler from the Formula Depot red triangle menu.
