Publication date: 04/28/2021
Options for Block Items
To view settings for the components in a selected design or subsystem, do the following:
To view the Configuration settings for a block shape, select the block shape in the System Diagram.
To view Configuration settings for more than one block shape, select multiple block shapes using the Arrow tool, press Control, and click multiple block shapes.
Distribution Options
Each block shape randomly fails according to its specified failure distribution. In addition, you specify a time unit for the distribution. The block shape’s time unit can be different from the time unit option that you specify in the simulation settings. The Turn On Count option is based on the number of times the individual block shape has been set to the On state.
The available failure distributions are listed in Table 12.2.
Table 12.2 Distributions and Additional Parameters
Property Type
Required Inputs
Exponential
Theta
Weibull
Alpha, Beta
Lognormal
location, scale
Loglogistic
location, scale
Fréchet
location, scale
GenGamma
mu, sigma, lambda
DS Weibull
Alpha, Beta, Defective Probability
DS Lognormal
location, scale, Defective Probability
DS Loglogistic
DS Fréchet
Nonparametric
data or data file
Estimated
estimated distribution, data, or data file
To see the formulas and parameterization for these failure distributions, see Distributions in the Life Distribution section.
