Quality and Process Methods > Measurement Systems Analysis > Statistical Details for Measurement Systems Analysis
Publication date: 04/28/2021
For more information about the calculations of the limits used in the Range Chart, see Control Limits for XBar and R Charts in the Control Chart Builder section. For more information about the calculations of the limits used in the Standard Deviation Chart, see Control Limits for XBar and S Charts in the Control Chart Builder section.
Computation of Intraclass Correlation and Probable Error
Intraclass Correlation without bias is computed as follows:
Intraclass Correlation with bias is computed as follows:
Intraclass Correlation with bias and interaction factors is computed as follows:
Probable Error is computed as follows:
Note the following:
= variance estimate for pure error
= variance estimate for product
= variance estimate for bias factors
= variance estimate for interaction factors
Z0.75 = the 75% quantile of standard normal distribution
