Publication date: 04/30/2021
Compare Parameter Estimates
The Compare Parameter Estimates report gives results for testing the equality of parameters across the levels of the grouping variable. There is an Analysis of Means (ANOM) report for each parameter, which tests whether the parameters are equal to an overall mean. If the result for a parameter exceeds the decision limits, then the parameter is different from the overall mean. Figure 13.11 shows the ANOM report for growth rate estimates. Select Compare Parameter Estimates from the fitted model’s red triangle menu to add the report.
Figure 13.11 Parameter Comparison for Growth Rate Estimates
The Analysis of Means red triangle menu contains the following options:
Set Alpha Level
Sets the alpha level for the test.
Show Summary Report
Shows or hides a report containing the parameter estimates, the decision limits, and whether the parameter exceeded the limits.
Display Options
Contains options for showing or hiding decision limits, shading, and the center line. Also contains options for changing the appearance of the points.
For more information about the Analysis of Means report, see Analysis of Means Methods in Basic Analysis.
