Build a Taguchi Design by selecting DOE > Classical > Taguchi Arrays. First define your responses and factors. Next, continue to the design options, generation, and evaluation. The design process follows the flow in Figure 14.8. See The DOE Workflow: Describe, Specify, Design.
Figure 14.8 Taguchi Design Flow
