Variable clustering provides a method for grouping similar variables into representative groups. Each cluster can be represented by a single component or variable. The component is a linear combination of all variables in the cluster. Alternatively, the cluster can be represented by the variable identified to be the most representative member in the cluster.
You can use Cluster Variables as a dimension-reduction method. Instead of using a large set of variables in modeling, either the cluster components or the most representative variable in the cluster can be used to explain most of the variation in the data. In addition, dimension reduction using Cluster Variables is often more interpretable than dimension reduction using principal components.
Figure 16.1 Example of Correlation Map for Variables
