Multivariate Methods > Cluster Variables > The Cluster Variables Report
Publication date: 09/28/2021
By default, the Cluster Variables report displays the following:
Color Map on Correlations
Cluster Summary
Cluster Members
Standardized Components
Tip: In any of the Cluster Variables reports, select rows in order to select the corresponding columns in the data table. Press Ctrl and click the row to deselect the column in the data table.
