Design of Experiments Guide > Covering Arrays > Covering Array Window
Publication date: 09/28/2021
Image shown hereCovering Array Window
The covering array window updates as you work through the design steps. For more information about the general flow of DOE windows, see The DOE Workflow: Describe, Specify, Design. The outlines, separated by buttons that update the outlines, follow the flow in Figure 20.17.
Figure 20.17 Covering Array Flow
Covering Array Flow
