From the JMP Starter window, you can launch a specific analysis (Bivariate, Oneway, Logistic, or Contingency). If you select this option, specify the correct modeling types (Y and X variables) for the analysis (Table 4.1).
To launch a specific analysis from the JMP Starter Window, click the Basic category, and select a specific analysis.
Most of the platform launch options are the same. However, the naming for some of the Y and X platform buttons is customized for the specific analysis that you are performing.
Platform or Analysis |
Y Button |
X Button |
Fit Y by X |
Y, Response |
X, Factor |
Bivariate |
Y, Response |
X, Regressor |
Oneway |
Y, Response |
X, Grouping |
Logistic |
Y, Categorical Response |
X, Continuous Regressor |
Contingency |
Y, Response Category |
X, Grouping Category |
