Publication date: 09/28/2021
MaxDiff Window
The MaxDiff Study window updates as you work through the design steps. The outlines, separated by buttons that update the outlines, follow the flow in Figure 19.7
Figure 19.7 MaxDiff Design Flow
MaxDiff Design Flow
The MaxDiff Study window opens showing the Design Options outline. Once you click Make Design, the Design outline appears. To construct the design table, click Make Table.
