When you click OK in the launch window, the Model Based Clustering report window opens, showing a Control Panel for fitting models. See Model Based Clustering Control Panel. As you fit models, additional reports are added to the window. See Normal Mixtures Report.
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
