Table 14.1 provides the formulas for the models on the Fit Curve red triangle menu.
Model |
Formula |
Polynomials |
where k is the order of the polynomial. These models can also be fit using the Fit Model and Fit Y by X platforms. |
Logistic 2P |
a = Growth Rate b = Inflection Point Available only when all response values are between zero and one. |
Logistic 3P |
a = Growth Rate b = Inflection Point c = Asymptote |
Logistic 4P |
a = Growth Rate b = Inflection Point c = Lower Asymptote d = Upper Asymptote |
Logistic 4P Rodbard |
a = Growth Rate b = Inflection Point c = Lower Asymptote d = Upper Asymptote Available only when the regressor values are positive. |
Logistic 4P Hill |
Logistic 5P |
a = Growth Rate b = Inflection Point c = Asymptote 1 d = Asymptote 2 f = Power |
Probit 2P |
a = Growth Rate b = Inflection Point Φ = Normal Distribution CDF Available only when all response values are between zero and one. |
Probit 4P |
a = Growth Rate b = Inflection Point c = Asymptote 1 d = Asymptote 2 Φ = Normal Distribution CDF |
Gompertz 3P |
a = Asymptote b = Growth Rate c = Inflection Point |
Gompertz 4P |
a = Lower Asymptote b = Upper Asymptote c = Growth Rate d = Inflection Point |
Weibull Growth |
a = Upper Asymptote b = Growth Rate c = Inflection Point Available only when both the response values and regressor values are non-negative. |
Exponential 2P |
a = Scale b = Growth Rate |
Exponential 3P |
a = Asymptote b = Scale c = Growth Rate |
Biexponential 4P |
a = Scale 1 b = Decay Rate 1 c = Scale 2 d = Decay Rate 2 Available only when the response values are positive. |
Biexponential 5P |
a = Asymptote b = Scale 1 c = Decay Rate 1 d = Scale 2 f = Decay Rate 2 |
Mechanistic Growth |
Cell Growth 4P |
a = Peak value if mortality rate, d, is zero b = Response at time zero c = Cell Division Rate d = Cell Mortality Rate Available only when the response values are positive and the regressor values are non-negative. |
Gaussian Peak |
a = Peak Value b = Critical Point c = Growth Rate |
Lorentzian Peak |
a = Peak Value b = Growth Rate c = Critical Point |
One Compartment Oral Dose |
a = Area Under Curve b = Elimination Rate c = Absorption Rate Available only when the response values and the regressor values are all positive. |
Two Compartment IV Bolus Dose |
α = β = a = Initial Concentration b = Transfer Rate In c = Transfer Rate Out d = Elimination Rate Available only when the response values and the regressor values are all positive. |
Michaelis-Menten |
a = Max Reaction Rate b = Inverse Affinity Available only when the response values and the regressor values are all positive. |
