The Normal Mixtures report gives summary statistics for each cluster:
• The Cluster Summary report gives the number of observations and proportion for each cluster.
• The Cluster Means report gives means for the observations in each cluster for each variable.
• The Cluster Standard Deviations report gives standard deviations for the observations in each cluster for each variable.
• The -LogLikelihood table gives the negative log-likelihood, BIC, and AICc. See Likelihood, AICc, and BIC in Fitting Linear Models.
• The Correlations for Normal Mixtures report gives the estimated correlation matrix for each cluster
