Publication date: 09/28/2021
Image shown hereOutput Options
Make Table
Constructs the Covering Array data table.
Back
Takes you back to the Factors outline. You can make changes to the previous outlines and regenerate the design.
Note: If you have defined Disallowed Combinations in the Restrict Factor Level Combinations outline, these are retained as a script. The script is shown in the Use Disallowed Combinations Script panel when you click Continue.
