Publication date: 09/28/2021
Recent Files in Projects
In a JMP Project, you can open a file from the Recent Files tool pane.
Tip: To hide or show the Recent Files tool pane, select Project > Show Recent Files. To specify which tool panes appear by default when you create a project, select File > Preferences > Projects and choose the initial tool panes.
Open a file
In the Recent Files tool pane, double-click on a file or drag it into a project.
Note: Open files that are saved to the project contents do not appear in the Recent Files tool pane.
