Once you have generated results from your data, JMP provides you with multiple ways to share your work with others. Here are some of the ways that you can share your work:
• Saving platform results as journals, projects, or web reports
• Saving results, data tables, and other files in projects
• Saving scripts to reproduce results in data tables
• Saving results as Interactive HTML (.htm, html)
• Saving results as a PowerPoint presentation (.pptx)
• Sharing results in a dashboard
Figure 7.1 Example of a Web Report
