Using JMP > Save and Share Your Data > Save a JMP Analysis as a Script
Publication date: 09/28/2021
After completing an analysis and receiving a report, you might want to save the process that you used to arrive at the report as a JSL script. You can save the script inside the data table, inside the report, or in a separate script window. To do this, click the red triangle in the report title and select the Save Script option that you prefer. See Save Script Menus in Reports.
Non-English versions of JMP can save scripts in either English or your local language. See General JMP Preferences.
