Using JMP > Save and Share Your Data
Publication date: 09/28/2021
Get Your Data Out of JMP
This chapter covers the following topics:
saving data tables as text files, SAS data sets, Excel files, and other formats
saving reports as interactive HTML and PowerPoint
emailing reports and data tables
saving analyses as scripts
saving parts of a report as a graphic
printing reports
copying and pasting reports
creating JMP journals or projects
saving JMP sessions
saving log windows
The method that you choose depends on how you want to interact with your analyses in the future:
If you want to interactively present your data, you might choose to create a JMP journal.
If you want to send data tables, linked reports, and other items to someone, you might choose to create a JMP project.
If you want to continue to explore a report later, you might choose to create a JMP report.
If you want to send a report to a non JMP user, you might convert the report to interactive HTML or a web report.
Contents
Save and Share Data Tables
Save Data Tables as Microsoft Excel Files
Save JMP Data as a CSV File
Save JMP Data as a Text File
Save JMP Data as a JSON File
Save JMP Data as a SAS Transport File
Save JMP Data as a Google Sheet
Save JMP Data as a SAS Data Set
Save Data Tables to a Database
Replace a Database with a Data Table
Save and Share Reports
Share Reports as Interactive HTML
Publish Reports to JMP Live or JMP Public
Save Reports as PDF Files
Save Reports as PowerPoint Presentations
Setting the Graphic DPI for Exported Graphics
Save a JMP Analysis as a Script
Save Parts of a Report in a Graphic Format
Print Reports
Copy and Paste Reports
Work with Projects
Create a New Project
Open Files in a Project
Rearrange Files in Projects
Save a Project
Project Workspace
Project Bookmarks
Project Contents
Recent Files in Projects
Project Log
Move Files into Projects
Write a Project On Open Script
Example of Creating a New Project
Create Journals
Example of Making a Journal for a Presentation
Create New Journals
Manage Links in Shared Journals
Add and Edit Outlines to Journals
Right-Click Options in Journals
Control the Display of Outline Levels in Journals
Add a Graph or Graphic to Journals
Customize Items in Journals
Prevent Modifications to Journals
Append Reports to Journals
Save Journals in Other Formats
Delete Items from Journals
Save JMP Sessions
Save Sessions upon Exiting JMP
Save Sessions Manually
Save a Log Window
