Arguments enable you to specify special modes and settings. To enable an argument, use the Enable(argument) command. To disable an argument, use the Disable(argument) command. Available arguments are shown in Table 13.7.
ALPHA_TEST AUTO_NORMAL BLEND CLIP_PLANE0 CLIP_PLANE1 CLIP_PLANE2 CLIP_PLANE3 CLIP_PLANE4 CLIP_PLANE5 COLOR_LOGIC_OP COLOR_MATERIAL CULL_FACE DEPTH_TEST DITHER FOG LIGHT0 LIGHT1 LIGHT2 LIGHT3 LIGHT4 |
LIGHT5 LIGHT6 LIGHT7 LIGHTING LINE_SMOOTH LINE_STIPPLE MAP1_COLOR_4 MAP1_INDEX MAP1_NORMAL MAP1_TEXTURE_COORD_1 MAP1_TEXTURE_COORD_2 MAP1_TEXTURE_COORD_3 MAP1_TEXTURE_COORD_4 MAP1_VERTEX_3 MAP1_VERTEX_4 MAP2_COLOR_4 MAP2_INDEX MAP2_NORMAL MAP2_TEXTURE_COORD_1 MAP2_TEXTURE_COORD_2 |
MAP2_TEXTURE_COORD_3 MAP2_TEXTURE_COORD_4 MAP2_VERTEX_3 MAP2_VERTEX_4 NORMALIZE POINT_SMOOTH POLYGON_OFFSET_FILL POLYGON_OFFSET_LINE POLYGON_OFFSET_POINT POLYGON_SMOOTH POLYGON_STIPPLE SCISSOR_TEST STENCIL_TEST |
