Design of Experiments Guide > Balanced Incomplete Block Designs > Build a Balanced Incomplete Block Design
Publication date: 11/29/2021
Build a Balanced Incomplete Block Design by selecting DOE > Special Purpose > Balanced Incomplete Block Design.
Figure 24.4 Balanced Incomplete Block Design Window
The Balanced Incomplete Block Design window updates as you work through the design. The steps to build a BIBD follow the flow in Figure 24.5.
Figure 24.5 Balanced Incomplete Block Design Flow
